Long press on the blank area to select the widget to add to the page.
1.Press and hold the widget, then move it to an empty space on the desktop to add it;
2.Press and hold the widget, then move it downwards to delete it.
I can get widget by long press, drag and drop widget onto home screen! But can't remove widget after doing so! When I long press the widget from home screen to remove it, the luncher keep stop working and back to the main screen.
Please help!
@Quoc Nguyen We are wondering if you uninstall the App as the video shows.
@Roadanvi Support thanks for your reply! It was the clock app causing the crash! When I try to remove clock widget that I added before, it keep crashing with the launcher!
Everything's good now! Thanks again!
