Brightness Adjustment
1.Go to the Brightness on the upper right corner to change the Brightness.
2.Go to Settings > Display > change the Brightness level.
Is there a way to dim the backlighting even more at night?
@Ronald Hernandez Have you already setup to night mode? Here is the instruction:
https://www.roadanvi.com/community/forum/topic/126496/day-night-mode-switch-how-to-adjust-brightness-settings-on-hs-x12-series
@Roadanvi Support Correct. Still too bright at night on long drives.
