My radio reception is not good. I have checked the connection multiple times. Do I need to Plug it in a new way? What is the Wifi antenna used for and do I need to externally mount it?
@George Neville Hi there, we are wondering if you could send us a video to demonstrate the issue that you mentioned about the radio reception, note that electronic devices inside the vehicle, such as power windows, power mirrors, or other electronic products, if not properly shielded, may interfere with the radio signal.
As to the Wifi antenna, you should connect it or it will hardly receive 5G wifi signal.
